Help with power steering line
I've found a pinhole in my power steering fluid return line between the gears and the reservoir. Thanks to NovaResource for pointing out the hmaservice site, I was able to locate an image of it. I am wondering how to remove this hose; it's fairly simple, except that both hoses are on the mount on top of the rack body and run through rubber insulators, which the hose isn't going to fit through when I try to remove it. How can I get only the return line out of this? It's hard to see, so I don't know if they are able to be separated.
