How do I remove Ball joint from lower arm
Old 10-25-2009, 10:17 AM
dennisf72's Avatar
Angry How do I remove Ball joint from lower arm
I am changing the the left transaxle on my girlfriends 2001 Hyundai Sonata. I have the wheel and lugs off. I took the nut off the Tie Rod. I have the nut off the Ball Joint and I even took the bolts off the control arm so that I could lower the arm out of the way.
My problem is I cannot get the Ball Joint to come out of the arm. I have tried a Pickle Fork to pop it and the Ball Joint remover I have does not fit. I have also tried using a pry bar but no luck so far. It seems the Hyundai Ball joint sits on top and not below like other cars.
Any suggestion on how to get that Ball Joint out of the arm?
Old 11-02-2009, 11:21 AM
Sashimi's Avatar
Hit the knuckle with a solid hammer.
Old 11-17-2009, 11:46 PM
Vavso's Avatar
Default Sashimis right
Give it a good shot with a hammer but shot placement is important ( Knuckle shot only )
IM Buddy8
12-15-2010 11:11 PM
Diver69
08-19-2009 07:06 AM
bernd
03-12-2009 10:35 AM
Policy Peddler
04-29-2008 12:47 PM
John Brodzinski
03-03-2006 03:32 PM
Quick Reply: How do I remove Ball joint from lower arm
