How to remove front headlight assembly
Old 10-06-2008, 01:49 PM
bobisnext's Avatar
Default How to remove front headlight assembly
I want to replace the existing low beam lamps witha set of Xenon lamps/ballasts. (It doesnt appear that I have enough room to just swap out the existing lamps w/o taking out the headlight assembly.)
Has anyone done this? The owner's manual is not clear asto how many bolts need to be removed. (I see three on the top and one on the inside towards the radiator). Is that all?
How difficult is it to remove the assembly?
thanks
Old 10-06-2008, 02:50 PM
rallyman's Avatar
Default RE: How to remove front headlight assembly
You don't mention what year your Sonata is but mine is a 2006 and there are two bolts on the top and one on the inside towards the radiator. If you remove these anddisconnect the wiring harness connector which plugs into the back of the headlight unit it will slide right out easily.
Old 10-06-2008, 03:51 PM
ORIGINAL: bobisnext
thanks
What year Sonata?
Old 03-25-2009, 12:42 PM
Xyligan4ever's Avatar
just recieved my HID kit and going to replace my factory bulbs, any advice as to whichsteps/precautions to take, and how to take out headlight assembly?
sonata 09
Old 03-25-2009, 04:03 PM
ken99's Avatar
Originally Posted by Xyligan4ever
any advice as to...how to take out headlight assembly?
sonata 09
1.Disconnect the negative (-) battery terminal.
2.Loose the mounting bolts (2EA) of head lamp.
3.Remove the head lamp assembly after disconnecting the lamp connectors.
Take care that holding clip (A) is not to be damaged.
4.Remove the bulb caps from the head lamp assembly after turning in the counter clock-wise direction.
A : Head lamp high bulb
B : Head lamp low bulb cab
C : Turn signal bulb cab
5.Installation is the reverse of removal.
Old 03-26-2009, 09:25 AM
Thank got my HID's installled yesterday, 6000k on 09 sonata
was fairly easy along the way
Old 03-26-2009, 05:31 PM
173rd's Avatar
Default Head light
Which kit did you buy and how much?
usmarine1988
06-20-2011 06:47 PM
sabowman1@gmail.com
09-13-2010 09:05 AM
n707jt
08-18-2009 07:35 AM
thx1971
04-13-2009 09:15 AM
mat036
11-01-2007 09:18 PM
Quick Reply: How to remove front headlight assembly
