low beam lamp replacement help
RE: low beam lamp replacement help
Not sure about the Sonata, but on the Elantra the easiest way to get to the bulbs is to remove the whole headlamp assembly be removing three bolts and disconnecting the wires that go to the assembly. Once out of the car, it's fairly simple to get to the bulb. As far as what bulb part number to use, just look it up at the auto parts store.
Michael Andrew Sievers
02-14-2012 04:41 PM
tiBuronGt
01-03-2009 10:31 PM
