2010 Sonata USB/Auxiliary Issues
Old 01-26-2018, 01:25 PM
Immaculatedegenerate's Avatar
Default 2010 Sonata USB/Auxiliary Issues
Hi all,
I've got an issue with the USB/Auxiliary jacks in my 2010 Sonata. Playback cut out out of nowhere. Nothing worked. Thought it was a poor connection to the cord so I jiggled it around and nothing. So I went replaced it with an OEM like the one shown.
At first, nothing and as I sat for 5-10 minutes googling trying to figure out the issue, it started to play. I had it connected to my phone via an aux cord. Now it only works intermittently after the car has been running for a bit. This was never a problem before. I've considered replacing the head unit but I don't know if there's anything else I should check before I go that far. The radio and CD work just fine. Any ideas?
Thanks!
Old 04-26-2021, 11:30 AM
Agent Dean's Avatar
Default This works for me
So when I was trying to use the USB port apparently I pushed too hard and the jack was pushed all the way down into the unknown below. I removed this rectangle opening so I could push the Jack back through its slot but that didn't work so now I just go through the rectangle. That worked for a little while and then I'm not sure what happened but now in order for music to play from my phone to the speakers I have to have my phone plugged in with an audio jack cord AND usb charger cord at the same time. I'm about to order a new one and install it. Also when my daughter plugs in her I found charging cord it doesn't work at all and it did before The accidental push through.. I have a Android phone
aww
07-10-2023 10:22 AM
jdanniel
04-16-2021 03:28 PM
Alenzie
01-19-2019 05:01 PM
tsedgwick
07-10-2017 11:12 AM
Matt Voss
01-28-2016 11:06 AM
Quick Reply: 2010 Sonata USB/Auxiliary Issues
