Timing belt and counter balance belt
Old 10-08-2008, 07:53 AM
Rhondas's Avatar
Default Timing belt and counter balance belt
When a Timing belt job is done on a 2001 4 cyl sonata , should the mechanic replace the counter balance belt also I had my belt done at 56K , Now I hear a noise at 107K , so If I have the job done what ball park figure $$$$$are we talking about in price for such a job.
Old 10-08-2008, 01:48 PM
ken99's Avatar
Default RE: Timing belt and counter balance belt
There is no counter balance belt on the engine. I think the counter balance shafts are gear driven off the oil pump drive. There are 2 drive belts serving the water pump, air conditioning compressor and the power steering pump.
I would have the noise diagnosed before automatically spending money on a timing belt replacement. The noise may be unrelated to the timing belt, which can still wait ~9K miles before replacing it. If dealing with the noise means partially disassembling the engine, yes, you could have the belt replaced now. Timing belt replacement cost? $300 to 500 depending on where you have your work done, an independent mechanic or a Hyundai dealership.
Old 10-08-2008, 07:26 PM
Rhondas's Avatar
ORIGINAL: ken99
Thanks Ken but I found different information on the counter balance belt on the Hyundai shop manual, here it is its there see picture.
[IMG]local://upfiles/6342/67A7607764794A38A74CD886FA604118.jpg[/IMG]
Old 10-08-2008, 09:51 PM
ken99's Avatar
You are right and I stand corrected. I pulled up the diagram for the oil pump.
[IMG]local://upfiles/4972/067AD3936EF84A8F843CED4CCED2B370.gif[/IMG]
It appears the counter balance shafts are coming off the oil pump gearing. The diagram you refer to shows "timing belt B" driving a "counter shaft", but I found another reference that confirms this is the right side counter balance shaft.
I would still have the noise identified before automatically replacing both timing belts.
Old 10-15-2008, 06:47 PM
Rhondas's Avatar
ORIGINAL: ken99
Thanks Ken
but did you think the counter balance belt should also be replaced with a new timing belt while its all opened?
Old 10-15-2008, 07:09 PM
ken99's Avatar
Quite simply, yes.
mevin69
11-06-2011 03:14 AM
hemje
10-25-2009 09:50 PM
JoeMario
01-11-2009 04:47 PM
Rhondas
11-01-2008 02:48 PM
alvinsum
03-01-2007 07:39 AM
Quick Reply: Timing belt and counter balance belt
