04 tiburon starting issue
04 Tuscani gt has issue starting once it's already been started throughout the day. First/cold start starts fine normally. About 4-10 sec it'll fire until th car will turn over. And when i run the car it smells super rich. Not sure what either of these problems are as I just got the car. No check engine lights. I ran some carb cleaner thru the throttle body fuel injector cleaner thru the fuel marvel mystery oil in the oil sea foam in the intake. Cleaned out quite a bunch of carbon. Also does anyone have any tips on the clutch? Anyway I can adjust it? It seems i have to really slam it to the floor to get the car into gear when it's cold. Any way to adjust this on this car? And the passenger window doesn't work is this a common problem? Just the motor normally?
