Dash light and running light issues on 97 Tiburon
I would like any information anyone has on running light issues. I've got a 97 Tiburon with a 2001 front end swap. When I purchased it, the dash lights worked. They suddenly went out, I've checked the fuses and they look fine [sm=icon_blah.gif]been there done that.... what would cause this (burnt out bulb????) and how would I go about getting back in the dash to replace the bulb?
Second issue, one running light keeps burning out, I'm thinking bad ground? Is this another known issue.... everytime I replace it its blown within 10 minutes.
And, if your wondering a little bit about me, HUGE VW nut, but I've turned to Volvo's for my speed fix. This Tiburon is a nice DD... probablya keeper (a 97 w/ 81k!!!)
RE: Dash light and running light issues on 97 Tiburon
Bulb is 12V40/3CP..... and its blown twice... is this the right bulb?
[edit] Ok, just did a little bit of searching, found out that the marker lights are a 2357NA vs just teh 2357's I've got. Apparently one is a higher amperage and burns a bit brighter..... that would explain my situation, but can someone verify this information, its only come from looking at part numbers on www.autozone.com and noticing a difference.
Damnit, I hate little nitpicky things like these... I just want the car in stealth mode, no getting pulled over for a burnt out bulb or other BS [end edit, end rant]
tru2au
10-16-2012 11:28 PM
mitchlub
03-28-2010 06:38 PM
