My Tiburon Won't even fire
Old 10-08-2015, 04:15 AM
Brandi Dodge Owner's Avatar
Default My Tiburon Won't even fire
Ok
I got a 1997 Hyundai Tiburon.
It over heated and hasn't ran ever since. It turns over fine but won't fire .... I need help with this
Old 10-08-2015, 12:20 PM
avisitor's Avatar
Overheating can sometimes cause the head gasket to fail which then allows for a number of possible problems
One is coolant into motor oil or the other way around
Another is loss of compression which would not be helpful in starting an engine
Or it could be a bad crank or cam sensors
Even something else that I haven't heard about
It should be back to basics and start by checking to see if you have spark, fuel
And let that lead you to where look
Good luck to you
mattroth7474
11-10-2011 02:00 PM
NeverKnowEnough
11-25-2010 03:41 AM
red13
06-26-2009 02:47 PM
Neoimmortal
08-19-2005 04:15 PM
timber
03-31-2005 02:15 PM
Quick Reply: My Tiburon Won't even fire
