Valor DTS 603w In Dash DVD Player
Old 01-07-2008, 06:03 PM
Ksmooth697's Avatar
Default Valor DTS 603w In Dash DVD Player
I boughta Valor DTS603w in-dash DVD player.After being professionally installed,my Speedometer and odometer stopped working, but when I turned the Unit Off everything worked fine. I had my car checked with Hyundai and all they could find was the radio causing the problem. Is this possible or what. Now that my Kennwood CD player is back in the car the speedometer and odometer work fine. Circuit city blew my Kennwood CD player it only works with a CD in and you still can't change tracks, volume or anything.
Old 01-08-2008, 02:37 PM
madindian1's Avatar
Default RE: Valor DTS 603w In Dash DVD Player
yes it is the radio that's causing the problem. are you in ga?
Old 01-10-2008, 03:36 PM
Ksmooth697's Avatar
no I Live In WV. I Read This In Another Forum: I had the same problem installing an Alpine stereo in my fiancée's 2007 Tiburon. The solution I found was to disconnect the amplifier turn-on wire (Blue-White on the Alpine and White-Orange on the Tiburon). Since there is no external amplifier in her Tiburon the wire was not necessary and doing that solved the problem. Will This Work.
Old 01-10-2008, 10:42 PM
madindian1's Avatar
it probably will cause when i looked at the schematic i noticed that the speed sensor signal goes to the amp and the radio, so some how it's interfering with the speedo. didn't actually investigate what's really happening. try it though it might work.
Fastrotaries
08-08-2012 09:27 PM
sulee
05-06-2009 10:00 AM
firecracka1966
01-18-2009 09:01 AM
mxzdan
11-02-2008 08:49 PM
nikos123
06-17-2005 03:27 AM
Quick Reply: Valor DTS 603w In Dash DVD Player
