tucson 2006 driver side Power windows stopped working
Old 11-30-2015, 01:00 AM
abuhuzaifa's Avatar
Default tucson 2006 driver side Power windows stopped working
Hi Friend's,
since 1 year i am using tucson 2006 full option, alhamdulillah i am satisfied with this car, since 1 week i am facing driver side power window issue one morning it stooped working for a while then it's go to normal position .. next day it's totally not working .... ..
kindly support .. need your support to fix the issue..
Thanks
Old 12-01-2015, 08:47 PM
avisitor's Avatar
It could be a bad power window motor or bad switch or even bad wires
You have to test them to find out which is not working
It is made more difficult by being intermittent
A hard failure would let you know what works and what doesn't
Intermittent means you have to guess which is really the culprit during testing
Start by removing the door trim and panel that covers the access to the motor and switch
Look at the wiring and test if it functions or not while moving the wiring a little
Use a voltmeter and check voltages at the switch and motor
If you have another switch handy to try replacing it and testing to see if the switch is the problem
Good luck
Old 12-05-2015, 05:11 AM
abuhuzaifa's Avatar
Thanaks for your reply..
Renee S
02-21-2024 01:05 AM
mdd_8
12-09-2011 04:15 AM
CSilivestru
02-01-2011 11:31 AM
FIGMAN
08-22-2008 06:35 PM
laine1998
12-29-2004 01:18 PM
Quick Reply: tucson 2006 driver side Power windows stopped working
