Hyundai Veracruz This crossover combines the functionality of a minivan in a sleek exterior with luxury qualities.
Ignition key wont turn
Old 12-20-2016, 10:40 AM
jimmy70's Avatar
Default Ignition key wont turn
Hi, I have a 2008 VC limited with a proximity key and recently, the proximity feature stopped working and I had to insert the key to turn the car on. Now even inserting the key is hardly working and have to try many times (10+) before the ignition turns. This is happening with the 2 Fobs which has new batteries - I heard that this could be a problem with the immobilizer! I would appreciate if someone can help me with diagnosing the problem
Thanks
Old 12-21-2016, 06:53 AM
jimmy70's Avatar
Does anyone know or have instructions how to get to the immobilizer behind the dash?
Thanks
Old 12-22-2016, 10:04 PM
avisitor's Avatar
Not sure what you're problem is??
Does the engine crank and not start?
Or does the key not turn in the lock?
Does the immobilizer light go out?
Did you try changing the battery on the key fob?
Are the batteries put in correctly?
I have no advice or instructions on how to egt the immobilizer out. Sorry.
HermanPWillis
03-22-2018 07:33 AM
jesmond
03-03-2014 11:14 AM
poch
10-16-2010 09:13 AM
gvsuman
08-22-2007 07:25 AM
Quick Reply: Ignition key wont turn
