Hyundai Veracruz This crossover combines the functionality of a minivan in a sleek exterior with luxury qualities.
Veracruz 115 Volt Power outlet
Old 08-16-2014, 08:55 AM
slushpup5's Avatar
Default Veracruz 115 Volt Power outlet
I have a 2008 Veracruz. I plugged a 120 volt device in to the 115v rear power outlet that looks like a household outlet. Didn't realize my mistake at the time. I blew the 30 amp fuse that's in the engine compartment. I replaced the fuse but it blew out when I attempted to use the outlet again. Is there a second fuse or relay that I have to replace?
Old 08-20-2014, 07:00 AM
The problem is what you are plugging into that outlet. It's too much for it. Replace the fuse again and try plugging something small into that outlet. It should work. If not, you may have damaged the outlet the first time the fuse blew.
Old 08-23-2014, 06:28 PM
slushpup5's Avatar
I should have made it clear that I used a proper voltage/amp device when it blew the second time. Just returned from camping so I'll get another fuse and try once more.
Old 10-18-2021, 04:38 PM
livo's Avatar
I have 2008 Veracruz in Canada
My power outlet on the passenger side at the back clearly says 12 volt
Is there another at the back for 115/120 volt, or have you made a mistake and have just 12 volts like me?
Old 10-26-2021, 09:20 AM
mikeyb's Avatar
The power outlet on my 2010 Veracruz stopped working also. I replaced the fuse and the relay and still nothing. any ideas?
doux
01-20-2015 04:00 PM
nikitajazz
02-21-2013 08:09 PM
ronnyjoe
07-01-2011 06:59 AM
golferman
01-05-2009 03:32 PM
lgwapnitsky
01-09-2008 02:56 PM
Quick Reply: Veracruz 115 Volt Power outlet
