xg300 tops bolt on strut...help!!!
Old 10-03-2014, 02:34 PM
mkwasnie's Avatar
Default xg300 top bolt on strut...help!!!
I have a 2001 xg300. Got the struts off (whew) and cannot get the top bolt off the strut. The bolt just turns with the shaft. Tried impact wrench, tried using vise grips on the tip of the shaft--nothing works, everything just turns. Any idea's??
Old 02-13-2015, 05:42 AM
e3tom's Avatar
Which bolt ? The one that clamps the fork to the damper bottom ?
Just cut it and get a new one. I had to replace such bolts on my Trajet since one just shore off when trying to release the nut ...
Or are you talking about the rod nut that attaches the damper/shock to the strut mount ?
Try making it hot. It should be tightenend with 25Nm/18lb-ft only so it's surprising it's that hard to open.
In case you solved your problem in the last 4 months it would be nice to report here.
joezek
09-23-2013 10:54 AM
south20345
02-28-2012 10:40 AM
shawnboy
12-30-2007 02:23 AM
2fast4yu
04-26-2007 11:09 PM
JGeZau
10-31-2005 07:43 AM
Quick Reply: xg300 tops bolt on strut...help!!!
