2002 Accent rear bumper cover removal
Old 07-28-2008, 07:50 PM
bobjhunn's Avatar
Default 2002 Accent rear bumper cover removal
My daughter's Accent was slightly hit from behind and her rear bumper cover was cracked pretty badly. I'm trying to fiqure out how to get the old one off so I can replace it with a new one. Does anyone have a diagram on the rear bumper assembly, Also a fiqure on how much a new bumper cover will cost her?
Old 07-28-2008, 09:01 PM
Default RE: 2002 Accent rear bumper cover removal
REMOVAL AND INSTALLATION
1. Remove the transverse trim and luggage rear trim.
2. Loosen the 2 mounting bolts and 2 nuts from the luggage rear trim inner rear bumper cover.
3. Remove the rear combination lamp.
4. Loosen the 3 mounting screws on the mud guard, remove the mud guard, and loosen the rear wheel house inner mounting screw.
5. Loosen the 6 mounting screw on the upper rear bumper cover.
6. After loosening the rear bumper cover inner rail mounting bolts (Left : 2, Right : 2), remove the rear bumper assembly.
7. After loosening 5 mounting screw on the rear bumper cover, disconnect the cover from the rail.
8. Installation is the reverse of removal.
Old 07-28-2008, 09:32 PM
bobjhunn's Avatar
Thank you so much. I really appreciate it.
Old 10-09-2017, 10:17 PM
Selectrick's Avatar
Are diagrams no longer available?
jim4802
05-04-2014 11:02 AM
YossiD
06-01-2011 10:26 AM
ljda1
12-21-2008 02:01 AM
bobjhunn
08-02-2008 09:07 PM
mattcg1
02-13-2008 01:52 AM
Quick Reply: 2002 Accent rear bumper cover removal
