Hyundai Entourage This minivan boasts of being one of the safest vehicles in its class.
2007 Entourage -- Change Spark Plugs?
Old 06-07-2009, 10:02 PM
zachunderwood's Avatar
Default 2007 Entourage -- Change Spark Plugs?
Just wondering if any else out there has faced down the challenge of chainging the back (3) spark plugs on a 2007 Entourage minivan. I would imagine the 2007 Kia Sedona would be the same way.
Thanks for your help!
Old 06-08-2009, 01:57 PM
Why are you changing the plugs? They don't need replacement until 100K miles.
Old 07-10-2009, 08:37 AM
The original plugs are platinum, your not supposed to replace them until 100K. Also, your Entourage is a real pain to replace the back three plugs, I think you have to remove the intake, etc. I'd leave them alone unless you had a problem, not something to change just for fun.
Old 07-10-2009, 08:51 AM
The original plugs are NGK ifr5g-11, which is iridium. Plugs don't get any better. Mess with it at your own risk (void the warranty).
Old 07-13-2009, 01:50 PM
sos0327's Avatar
For me it's better not to change the spark plugs unless it's important, as jsinton has said, your not supposed to replace them until 100K. But if you really want to change it then it's up to you...
Old 07-15-2009, 07:31 PM
hatda02's Avatar
I dropped in tonight to post in the Entourage forum and saw this. My wife just got rid of our faithful Santa Fe for no reason other than wanthing something newer....which sucks...and brings me to this.
The Santa Fe's back three plugs are the same way where you have to remove the intake and a few other items to get to them. For the Santa Fe I believe the labor time was something like 1.5 or 2 hours just for plugs. I did them myself in about 2 hours and was really no problem if you properly remove, label, and order the items as you remove them. After pulling the cover off the Entourage to change the filter about 10 minutes ago this motor will be no different.
But everyone is right. The book says Iridium at 100k. My only question for the plugs that I could not find in the book is TQ specs and the gap. Or maybe those plugs come pre-gapped? I know plugs come pregapped for my 4Runner. I wonder if these will be the same (not that I will have to do them for 4 to 5 years, but I like to be ready)
Old 07-15-2009, 08:12 PM
Plugs = NGK IFR5G-11
Gap = 1.0 ~ 1.1 mm (0.0394 ~ 0.0433 in.)
Torque = 15-22 lb-ft (200-300 kg-cm, 20-30 Nm)
Old 10-25-2009, 06:16 PM
PlulaRof73's Avatar
Default 2007 Entourage Change Spark Plugs
I have a v6 2wd 05 Tucson with 31k on it. I just did a service pack today dealer said we had to do it to keep warranty fresh, bunch of hit. Anyways it cost 294.00 plus tax, which includes oil change, transmission change, flush and replace coolant, rotate tires, clean and adjust brakes, new air filter and a car wash and a bunch of inspections. My question is though, When should you replace the spark plugs on this vehicle? they said it is 118.00 extraThanks guys
Old 10-25-2009, 08:18 PM
Check your owners manual. My 2006 Tucson calls for the plugs to be changed at 100K miles.
Ed1976
10-22-2013 08:31 AM
uhlan
06-16-2012 05:15 PM
joe
01-17-2008 07:35 AM
Boomer
04-23-2006 03:36 PM
joe
10-24-2005 01:26 AM
Quick Reply: 2007 Entourage -- Change Spark Plugs?
