tail lights turn on with car off
Old Jul 28, 2009 | 07:45 AM
haw77's Avatar
Default tail lights turn on with car off
tail lights turn on by themselves with the light switch off and the ignition switch off the only way to disable them is by taking the bulbs out of the sockets or pulling the fuse my car is a 2006 sonata
Old Jul 28, 2009 | 08:19 AM
What part of the tail lights? The lower powered parking lights or the brighter brake lights? It's possible the brake light switch on the brake pedal is misaligned or broken.
Actually, I believe there is a TSB and recall for most Hyundais and Kias about bad brake light switched. I have an appointment to take my wifes 2006 Kia Sedona in this Friday and I need to make an appointment for my 2006 Tucson.
Old Aug 7, 2010 | 12:46 PM
larry l's Avatar
Make sure it is the switch. There's more than the switch at play here. May be a more simple fix. Pulling up on the pedal will not show for sure if its the switch, since a good switch still cannot make contact if the plastic stop is missing. I had the same problem and found that the plastic stop that is on the brake lever had deteroriated and was missing - found pieces in the carpet. It took less than a minute to replace and only cost $0.91.
The stop is about 1" diameter and 1/8" thick with a smaller diameter that pops into the hole on the brake pedal.
Old Aug 7, 2010 | 12:56 PM
This thread is over a year old.
Old Apr 25, 2016 | 01:50 AM
otis66's Avatar
There may be a little rubber stop that makes contact with the switch at the pedal. If that stop is not there your brake kits will stay on. Pushing the switch in should make the broke lites go off. No pressure on the switch will cause the brake lites to come on. You should be able to reach the switch with your hand and operate the switch.
This post is old but other people may have the same problem now and can read the post on this forum for help.
Old Apr 28, 2016 | 07:37 AM
avisitor's Avatar
This thread is over six years old
psychodoodbrij92
Mar 28, 2019 11:54 AM
Walester
Apr 13, 2014 12:54 AM
ronnieoverholser
May 12, 2013 08:57 PM
ttewejnodnarb
Aug 28, 2006 11:36 AM
accentgsi02
Nov 29, 2005 09:57 PM
