Changing Front Brake Pads 2000 Accent
Old Mar 29, 2010 | 06:14 PM
JayTye4k's Avatar
Default Changing Front Brake Pads 2000 Accent
Can I change these pads in typical fashion without the use of a hub puller? I'm hoping that is the case.
Thanks in advance for any help!
Jay
Old Mar 29, 2010 | 06:47 PM
Unbolt caliper from it' mounting, and swap pads if that is all you plan to do.
It would be in your best interest to remove the mount bracket, pop the shims off the mount bracket, and file the rust down to bare metal, then re-assemble shims. Now apply lube to the shims where the pads will slide, you want the padds to move freely in the mount, otherwise they will drag, that is why I told you the get rid of the rust.
I want to say the rotors should pop right off, I do not recall those being trapped behind the hub...
silvertones
Dec 20, 2011 12:27 PM
tpx
Jan 2, 2011 01:06 PM
Ed1976
Sep 17, 2010 12:02 AM
steve1959
Sep 9, 2006 12:23 PM
marauder
Aug 10, 2006 12:10 PM
