Santa Fe master brake valve problem
Old Jul 22, 2010 | 05:47 PM
amnny's Avatar
Default Santa Fe master brake valve problem
I have a brake fluid leak where the two brake lines from the bottom of the master cylinder , they all connect into some type of prop valve where the brake lines go into... The fluid is leaking from bolts on bottom of this valve that have rubber o-rings tops to them and some type of valve inside...
I'm not sure what the part is called so I was hoping someone on here could help me out on what part it is so I can replace it.. or rebuild it or something...
abaton6
Apr 14, 2011 11:49 AM
abaton6
Jan 12, 2010 04:57 PM
TJDukit
Sep 18, 2008 03:39 PM
speeder
Mar 9, 2008 07:05 PM
90excelGS
Feb 19, 2008 07:28 PM
