07 sonata Which Piston to order?
I have an 2007 sonata with a 3.3. Water got sucked into engine and bent a connecting rod, and the crank scratched the piston. Hyundia lists 3 different pistons- std a, std b, and std c and 5 different rod bearings a, b, c, d, and e all std. A Hyudnai tec told me theres a series of letters behind the crank pulley that indicates which piston for which cylinder. I pulled the crank pulley and there are no letters behind the pulley. Today im going to pull the piston out and see if theres any numbers or letters on it. Any help would be much appreciated.
Connecting Rod Mark Location
http://www.hmaservice.com/data/Passe...G/edqf196a.gif Discrimination Of Connecting Rod Class Mark Inside Diameter 0 a 58.000 ~ 58.006mm (2.2834 ~ 2.2837in.) 1 b 58.006 ~ 58.012mm (2.2837 ~ 2.2839in.) 2 c 58.012 ~ 58.018mm (2.2839 ~ 2.2842in.) Crankshaft Pin Mark Location http://www.hmaservice.com/data/Passe...G/ecbf037a.gif Discrimination Of Crankshaft Class Mark Outside Diameter Of Pin I A 54.966 ~ 54.972mm (2.1640 ~ 2.1642in.) II B 54.960 ~ 54.966mm (2.1638 ~ 2.1640in.) III C 54.954 ~ 54.960mm (2.1635 ~ 2.1638in.) Place Of Identification Mark (Connecting Rod Bearing) http://www.hmaservice.com/data/Passe...G/ecrf021a.gif Discrimination Of Connecting Rod Bearing Class Mark Thickness Of Bearing E Blue 1.514 ~ 1.517mm (0.0596 ~ 0.0597in.) D Black 1.511 ~ 1.514mm (0.0595 ~ 0.0596in.) C Brown 1.508 ~ 1.511mm (0.0594 ~ 0.0595in.) B Green 1.505 ~ 1.508mm (0.0593 ~ 0.0594in.) A Yellow 1.502 ~ 1.505mm (0.0591 ~ 0.0593in) (11)Selection Connecting Rod Bearing Connecting Rod Identification Mark 0(a) 1(b) 2(c) Crankshaft Indentification Mark Ⅰ(A) A (Yellow) B (Green) C (Brown) Ⅱ(B) B (Green) C (Brown) D (Black) Ⅲ(C) C (Brown) D (Black) E (Blue) ----------------------------------------------------------------------- 6.Check the cylinder bore size code on the cylinder block. http://www.hmaservice.com/data/Passe...G/ecbf002a.gif Class Size code Cylinder bore inner diameter A A 92.00~92.01mm (3.6220 ~ 3.6224in.) B B 92.01~92.02mm (3.6224 ~ 3.6228in.) C C 92.02~92.03mm (3.6228 ~ 3.6232in.) 7.Check the piston size code on the piston top face. http://www.hmaservice.com/data/Passe...G/udrf001a.gif Class Size code Piston outer diameter A A 91.97~91.98mm (3.6209 ~ 3.6212in.) B B 91.98~91.99mm (3.6212 ~ 3.6216in.) C C 91.99~92.00mm (3.6216 ~ 3.6220in.) 8.Select the piston related to cylinder bore class. Clearance : 0.02 ~ 0.04mm(0.0008 ~ 0.0016in.) |
