1.5 compression readings?
Old Feb 19, 2008 | 07:56 PM
90excelGS's Avatar
Default 1.5 compression readings?
Hi, what are the compression #'s i should expect from a healthy engine. I'm familiar with the procedure. Thank You...
Old Feb 19, 2008 | 08:06 PM
Derrel H Green's Avatar
Default RE: 1.5 compression readings?
Notas important as to what the exact numbers should be,
but the differences in those readings between cylinders.
As I recall, the numbers should not be more than 10 pounds apart.
Old Feb 19, 2008 | 11:23 PM
90excelGS's Avatar
Thanks Derrel, So a 10# + variance could be considered as troublesome rather than a precentage of a whole value. I can agree with that.. But I'm still curious of what stock compression should be.
Old Feb 20, 2008 | 12:33 AM
ken99's Avatar
The Hyundai service site I mentioned in the other thread has a whole section in the General Engine pdf that discusses compression testing. Straight forward procedure as you would guess. Standard pressure is 192 psi with a minimum limit of 171 psi. Differential between cylinders shouldn't exceed 14 psi. Recommends a second "wet" test for any low cylinders, again a pretty standard procedure. It doesn't suggest a "leak down" test, but that would be smart to check valve and/or piston ring integrity on any engine you were preparing to spend money on.
Also, this engine has a rubber timing belt. I couldn't confirm that it is a true interference engine, but being derived from a Mitsubishi design, I would bet it is. You have implied previous service is suspect. I'd check the condition of the timing belt and perhaps change it now if the compression tests indicate an otherwise sound engine. It would be a shame to invest money in the car only to have the engine tank from a broken timing belt.
Archy
Dec 23, 2011 08:30 PM
dewy
Sep 18, 2011 07:26 PM
Hacken
Apr 7, 2011 12:16 AM
