1995 Hyundai Elantra Timing Belt Adjustment
Just wondering if someone can explain to me the proper procedure to tighten the timing belt during installation. I have put this car together once and bent 4 valves cause the timing slipped. This time I pulled the engine and want to be sure the belt is tight before it goes back together. Any help to set my mind at ease will be greatly appreciated.
RE: 1995 Hyundai Elantra Timing Belt Adjustment
Not too sure with tha model. Generally there is a tension pulley that you can set back but once again I don't know if this applies to you.
This is for a 1995 Elantra with 1.6L engine. Looks like it requires a special tool to change the tensioner. Not clear on the process of when I need to unload the auto tensioner. Think it is suppose to be after I adjust the tensioner pulley but not really sure. Wish there was a book available for this car but the only one I can find is the factory service manual and I don't want to spend that kind of money. All I need to n=know is the proper process of adjusting the tension on the timing belt and I can take it from there.
I am not sure at all. Send a message to Malik112099 he could probably help you out.
