2.7L mystery
Below is a picture of the intake manifold on a 2006 2.7L.
The vacuum diaphragm shown rotates something in the intake manifold. The seal on the part that rotates is bad and there is a vacuum leak. I find no reference to this in any parts diagrams. Do you know what this is? I need to order the seal for the manifold, but have no reference. https://cimg2.ibsrv.net/gimg/www.hyu...a8c4ab1b50.jpg |
I believe you would call it the variable length intake runner control.
Originally Posted by hanky
(Post 58714)
Special items like that are considered "Dealer Items". Any questions you have for specialty items like that a dealership parts dept should be able to answer any questions on parts used there.
Originally Posted by Tuscon123
(Post 58709)
The vacuum diaphragm shown rotates something in the intake manifold. The seal on the part that rotates is bad and there is a vacuum leak. I find no reference to this in any parts diagrams. Do you know what this is? I need to order the seal for the manifold, but have no reference. https://cimg2.ibsrv.net/gimg/www.hyu...a8c4ab1b50.jpg I'm wondering if you found a solution to the leaking seal on the variable intake actuator on this manifold? I have a Tucson with a vacuum leak, first repair was the two shaft seals on the throttle body, 14mm x 10mm if anyone is interested. Now that the throttle body leak is solved, now the two variable shaft seals are leaking. My local Hyundai dealer is not much use, in fact did not even know what I was talking about until I showed him this video describing it. |
| All times are GMT -5. The time now is 01:51 AM. |
