2000 Accent...
Old Jul 13, 2005 | 04:09 PM
1sickeg6's Avatar
Default 2000 Accent...
I have a 2000 hyundai accent i use for work, and it developed a problem recently. Not even a week ago it was running perfect, and now i get nothing. it wont even attempt to turn over and i dont know what the problem is. Im not hyundai savvy so i need some help please!!
Old Jul 14, 2005 | 03:41 AM
pure performance's Avatar
Default RE: 2000 Accent...
first off did you test the battery with a volt meter to make sure the battery is any good
next check the relay and make sure the battery terminals and cables are not all corroded up
then if all is good see if you have at least 12.5 volts at starter
if all good and you have a manual trans check the clutch switch
Old Jul 14, 2005 | 07:44 PM
1sickeg6's Avatar
got the battery checked and that was fine, i also replaced the starter relay and had the starter checked. I finally got irritated and took it to a shop and they fixed it. I guess it had a blown link and fuse and now it runs but the a/c no longer works. I am fed up with this car and give up. Thanks for all your help pure performance
bryanbuchi
Feb 27, 2009 06:42 PM
my2ktib
Jan 1, 2008 11:53 PM
