2000 Accent...
I have a 2000 hyundai accent i use for work, and it developed a problem recently. Not even a week ago it was running perfect, and now i get nothing. it wont even attempt to turn over and i dont know what the problem is. Im not hyundai savvy so i need some help please!!
RE: 2000 Accent...
first off did you test the battery with a volt meter to make sure the battery is any good
next check the relay and make sure the battery terminals and cables are not all corroded up then if all is good see if you have at least 12.5 volts at starter if all good and you have a manual trans check the clutch switch |
RE: 2000 Accent...
got the battery checked and that was fine, i also replaced the starter relay and had the starter checked. I finally got irritated and took it to a shop and they fixed it. I guess it had a blown link and fuse and now it runs but the a/c no longer works. I am fed up with this car and give up. Thanks for all your help pure performance
| All times are GMT -5. The time now is 03:14 AM. |
