corey059 |
03-21-2009 07:52 PM |
2001 Sonata Headlights Reversed
i have a 2001 sonata with the all in one style headlight assembly. each assembly contains two headlight bulbs and a signal light. while driving down the highway at night with my lights set to low beams i am constantly being flashed by oncoming drivers who believe i have my high beams on. what i have found is the following. on my car the day time running lights are the upper of the two bulbs. when i turn on the headlights and set them to low beams it is the only the lower bulbs which are on. this is the exact opposite to what i have seen on other 2001 sonatas. on the other vehicles i have noticed that the daytime running lights are the lower bulbs while the low beams with the lights turned on are the upper bulbs. i am the third owner of the car so at some point the setup has become the reverse of what it should be. do you have any suggestions on what steps i can take to switch it back to the proper setup. my dealership seems to be stumped by it, or they simply do not wish to fix it.
