2003 Sonata TPS
2003 Sonata V-6
Keeps blowing the TPS. 3 in the last few weeks Any ideas?? TY. |
What do you mean by blowing the TPS?
TPS is a variable resistor |
The sensor needs to be replaced.
3 in about 4 weeks. The check engine light goes on. I hook up my code reader. Says the TPS is a fault. I replace the sensor and reset the codes. The last one lasted about a week??? |
The return of the code doesn't mean the TPS is bad.
It could mean the wiring to or from the sensor has a problem. Is there any changes in the performance of the car? What code are you getting? Put in proper format PXXXX where the x is a number example is P0122 which is TPS signal too low Which sometimes is an intermittent signal wire short to ground Measure the voltage to the TPS Is it the reference voltage? Measure the signal wire and move the throttle Does the voltage follow the movement Can also measure Ohms (resistance) across the disconnected TPS (signal to ground) |
Thanks.
It's my neighbors vehicle. I told her that if it goes bad or throws a code again??? There is something wrong besides the sensor. There isn't much I can do and she'd have to take it to the local dealer. I do some work on mine and the neighbors vehicles but my specialty is marine repairs. Thanks again!!! |
