2004 Elantra 2.0 HVT XD Brakes
Old Aug 7, 2010 | 07:56 PM
Alan298's Avatar
Default 2004 Elantra 2.0 HVT XD Brakes
Hi, I am currently replacing the brake discs and have done the front with no problem. So far I have only tried to do the rear R/H but am unable to push the piston back in while using a piston tool. Any advice would be appreciated. Regards
Old Aug 8, 2010 | 07:37 AM
The piston on many (but not all) rear calipers must be turned when pressing it back in. Generally this is the case where the emergency/parking brake is part of the caliper and not a separate drum brake inside the rotor hat. The Elantra does use the caliper as the parking brake and it must be turned to be compressed back in. You need a tool that looks like this:
It goes on the end of an extension on a ratchet and it twists the piston back in (clockwise). Find the side of the tool where the studs best match the grooves in the piston.
See here:
http://www.youtube.com/watch?v=QuLEx...eature=related
Old Aug 8, 2010 | 08:12 AM
Alan298's Avatar
Many thanks for your advice and the link to yjre video. Now I know the procedure I am confident I will be able to fit the new pads. Thanks again
Regards Alan
glassfern53
Sep 5, 2015 02:47 PM
bugsy1989
Dec 18, 2009 08:11 AM
pabeaure
Aug 21, 2007 08:57 AM
rival22
Apr 4, 2006 10:34 AM
tom scarano
Feb 22, 2006 03:56 PM
