2004 Hyundai Accent Transmission (Overdrive?) Issue
Old Mar 30, 2015 | 09:05 PM
quesadiella's Avatar
Default 2004 Hyundai Accent Transmission (Overdrive?) Issue
I have a 2004 Hyundai Accent GL. Up until last summer, it was working perfectly fine. I drove about 50 miles up a mountain to visit family and unknowingly left the overdrive on (as I always have since I bought it 4 years ago). I'm assuming the strain of the climb + the overdrive did something to the transmission. I took it to Mobil 1 and they told me the problem was called 4th gear failure. Basically the overdrive went out I guess and the car is unable to shift past third gear into 4th. I asked a family friend who used to be a mechanic about it and he said this is a common problem for the overdrive in Hyundai transmissions.
Mobil 1's estimate was about the same value as the car's worth and I can't afford that ($2000+). The family friend I asked gave me multiple alternative options, the main ones being to remove the overdrive and replace it, buy a brand new transmission, or buy a used transmission.
I guess I'm looking for other opinions on this issue, or other options that I have. The car is actually a really great car otherwise, and since last summer I've still used it as my daily driver and other than the fact that I can't go on the highway or go past 50 mph, it hasn't exhibited any other problems. I've switched off the overdrive and as long as it remains off, the car operates without issue. I feel like I need to figure out the best way the fix the issue before anymore gears fail or the car quits working altogether.
Any responses are much appreciated
red
Sep 27, 2021 06:06 AM
hicksd67
Jan 27, 2012 06:27 PM
Davex
Oct 7, 2007 09:48 AM
dennis041948
Mar 27, 2007 12:41 AM
sidvisious5150
Mar 7, 2007 01:36 AM
