2005 hyundai santa fe 3.5
car will not start, checked and replaced battery and still nothing...any ideas? thanks............:mad::D
Wont start...
Where do we start ? 1 - key in ignition, turn key, no dash lights 2 - turn key, dash lights, no crank 3 - turn key, cranks, but no fire Had 3.5 yesterday with no compression, wires and coils had burn marks, suspect ignition voltage leak, washed cylinders with gasoline.. got it to light a fire, belched a load of smoke.. replaced plugs, wires, 3 coils, and an oil change. |
pero grande
key in, dash lights on, headlights work, eveything electrical works but car will not start or even crank....turn the key and nothing....thanks for any help.....put new battery in and nothing happens to change the situation
would the fuse link for starter have anything to do with the car not starting or cranking |
The starter might be dead. First thing to try: have a helper sit in the car, make sure the transmission is in PARK (or neutral in a manual) and their foot is on the brake. Then while they turn the key you tap the starter with a hammer. If the starter turns then the starter is bad. If it doesn't turn then check the voltage on the battery cable at the starter and also check the voltage of the wire that activates the starter while the key is in the START position.
thank you will try and let you know, right now heavy snow so will be a couple of days
| All times are GMT -5. The time now is 03:28 AM. |
