2007 Elantra will not crank to start
My 2007 Elantra will not start. Turn the key and nothing. New battery, alternator good. Cleaned battery cables and the ground to the car. Put the battery charger on for a few seconds and it starts and will run for the rest of the day. Help!
Get a DVOM or multi-meter and check voltage across the battery terminals
Both when the engine is running and not running Running should read 14 to 14.5 volts Not running should read 12 to 12.5 volts Remember that new doesn't always mean better/working right |
