2008 Santa Fe Oil Filter
Where is the oil filter located for a 2008 Santa Fe? How do you change filter?
RE: 2008 Santa Fe Oil Filter
What engine 2.7L or 3.3L?
This is the procedure for the 3.3L Lambda in the Sonata but it's the same for the 3.3L in the Santa Fe: http://sonata.jerrystout.us/tsb/diy_oil_change.pdf |
Thanks very much for the information. I never expected such adetailed response, I do appreicate it very much. I do have the 3.3L engine, so the information should be exactly what I need.
Hope to hear from you again.... Bob |
I was trying to download this change oil pdf. and get error messages.
This is the procedure for the 3.3L Lambda in the Sonata but it's the same for the 3.3L in the Santa Fe: http://sonata.jerrystout.us/tsb/diy_oil_change.pdf __________________ |
Originally Posted by rwko
(Post 19375)
http://sonata.jerrystout.us/ and then look for the DIY oil change file under DIY and Misc information. |
Thanks! for the additional info. Was able to download the .pdf.
Regards... rwko |
