99 Hyundai - Moisture - Misfires
Old Nov 8, 2006 | 10:41 AM
tiffanyk's Avatar
Default 99 Hyundai - Moisture - Misfires
HELP ME!!!
I've been having this problem off and on for over a year now! My spark plugs misfire in the rain or moist weather!. They miss, and sometimes even cut out completely so I'm running on three cylinders.
I've tried cleaning the spark plug wires and have even completely replaced them with a brand new Bosch set 5 months ago! I've heard about dielectric grease. Can I use that? How would I use it? Where would I get it? Any other ideas or tips for fixing/preventingthis???????
Is this common with this engine?
Help!!!!!!!!!!!!
Old Nov 10, 2006 | 02:53 AM
dean08's Avatar
Default RE: 99 Hyundai - Moisture - Misfires
So far from what I know, dielectric grease primarily helps in preventing corrosion, it lubricates and aids in keeping out moisture. Wurth and Luberex are few brands I am familiar with.
Old Nov 27, 2006 | 05:21 PM
Chris B Williams's Avatar
I assume this is only happening in the wet.
You could try spraying the leads with WD40 or equivilent, or the other cause that I have heard of, although I have not experienced it myself, is the crankshaft sensor could be faulty.
Best of luck.
Chris.
Old Dec 31, 2006 | 10:19 PM
sverre dahl's Avatar
i have a 98 tibb that does exactly that...beginning to think its a grounding problem but am convinced its a valve issue? heh i went through a starter already. i got a flashing CEL with some valve noise at startup. if i get it started and warmed up and dry it runs like a scalded baboon butt . i do know i have a idle sensor CEL. i'll find out what the new one is. i couldnt count the number of flashes. this problem is very annoying, i feel your grief, tiffany. i think i'll start with the grounding system
Old Jan 4, 2007 | 07:08 PM
surfdog4's Avatar
Take out the Bosch Plugs! It may be other things, but my son's 2000 was sputtering and stalling..took out the Bosch plugs and replaced them with NGK..fixed it immediately...i have read this problem on other forums as welll..the plugs are cheap and easy to replace so it's worth a shot IMHO..good luck!
Old Jan 30, 2007 | 07:47 PM
flave1's Avatar
in my opinion you could try checking for tracking on the leads or coil towers as ive had a few coupe,s that have arched across from the coils to earth. try it at night to see if you can spot the missfire.
skiesrblue
Nov 17, 2015 09:14 PM
sheldon957
Oct 18, 2011 07:28 AM
31337Fungi
May 17, 2011 04:11 PM
Uncle Scrooge
May 20, 2008 01:38 PM
