AC not cold after intake manifold gasket changed
Old Jul 30, 2024 | 04:14 PM
K-Robb's Avatar
Default AC not cold after intake manifold gasket changed
I brought my 2007 Hyundai Sonata 2.4 into the mechanic because my check engine light came on and the code reader showed P278, too lean at idle. They determined that the intake manifold gasket was leaking and replaced it. As I was driving home, I noticed that my AC was not getting as cold as it normally does. I recently was gifted this car by my mom and it has only 45,000 miles on it. Prior to taking the car in the AC worked beautifully. When changing the manifold gasket would there be anything related to the AC system that could have been affected? I don't want to assume they forgot something, but I also don't want to be taken advantage of and have to pay for an AC system repair that they caused.
Old Jul 31, 2024 | 12:01 AM
Yernaz's Avatar
Hey, it’s possible that while replacing the intake manifold gasket, the mechanic might have accidentally disturbed the AC system. They could have disconnected a vacuum line, sensor, or wire related to the AC, or even moved something out of place. I’d take it back and ask them to specifically check the AC connections, hoses, and any related wiring. It could be something simple like a loose connection or a hose that needs reattaching.
Old Jul 31, 2024 | 04:50 PM
K-Robb's Avatar
That is exactly what happened. I went back and they found it right away. Thank you.
K-Robb
Jul 30, 2024 04:09 PM
David Snyder
Nov 9, 2021 01:49 PM
Chris M.
May 15, 2018 07:32 AM
Florida_Orange
Jul 10, 2014 04:35 PM
