islandbry |
06-17-2010 08:17 PM |
Accent battery terminal replacement
I need to replace my positive battery terminal on my 2001 Accent. The original terminal is loose and can't be tightened any more and this is cheaper than replacing the cable (I'm poor). The original has two wires coming off the pos terminal, a thicker cable and a thinner wire that comes off of a separate bolt on the terminal that looks like it goes to the fuse box under the hood. I already have a regular terminal for one wire. Question, can i clamp the two wires together on the new terminal? Thanks for any help.
