brake lights not working
I have a 1992 Hyundai Lantra. The brake lights on the car are not working. I have checked the fuses and they seem fine. If anyone knows what else could be causing the brake lights not to work then could you please tell me.
Thank you |
Have you checked the globes, it's seems pretty obvious, but you would be surprised as to how many people forget.</P> If you have checked the globes, the next thing that I would do would be to bridge the brake light switch, which is located on a bracket that is fixed onto the brake pedal bracket, the brake lights work on a switch that activates the lights when the plunger is released.</P> Disconnect the plug to the brake light switch and then bridge the two terminals that run to your wiring harness with a paper clip.</P> Let us know how you go!</P><edited><editID>Dr. Hundi</editID><editDate>38297.9661458333</editDate></edited> |
| All times are GMT -5. The time now is 01:54 AM. |
