Check engine light
Old Aug 20, 2007 | 11:27 PM
idahotiburon's Avatar
Default Check engine light
I keep getting a check engine light on my 2001 Hyundai Tiburon and I have a aftermarket header and exhaust well I keep getting a code that states catalyst operates below threshold Bank 1 and keep resetting and erasing it. I keep getting it back so what is the deal here I need some help. I also have a new o2 sensor and that didnt fix it. Any help would be cool. Thanks
Old Aug 21, 2007 | 07:57 AM
Doohickie's Avatar
Default RE: Check engine light
The problem is probably the exhaust itself. You mess with the performance of the car, the sensors are bound to notice it. And since the onboard systems on cars these days determine whether you pass or fail inspection, you need to make the decision what's more important- an aftermarket exhaust or passing inspection? One option would be to run with the CEL and put the stock exhaust back on about a month prior to inspection. As long as the condition that produced the CEL is still present, the code will never clear.
jordanwake
Feb 6, 2011 08:13 AM
duude1
Feb 3, 2006 06:04 PM
mlowe
Dec 23, 2005 02:48 PM
Lydia1
Nov 1, 2005 09:45 PM
tomholl
Jul 28, 2005 12:53 AM
