check engine light on , need help please
i just came back from the mechanic and he scanned my car into their computer and this was the result,
-123 TPS failure -137 oxygen sensor -624 fan relat -1701 transmission tps failure -po743 evap system -po747 " " what do you guys recomend me to do first or try to fix first, thanks |
RE: check engine light on , need help please
Hi , would be eazyier to give you a answer if we had more info on your car ,make, model. year an motor size
99 hyundai tiburon 2.0
most codes don't pertain to your car. Have a Hyundai dealer check the system with the correct scanner
