Cranks bit won't start 06 Elantra
Recently my engine shut off on me and coolant was on the engine bay. My thermostat was broken. Replaced the thermostat, thermostat housing, and radiator. Now my car only cranks but won't turn on. I'm confused on what could of happened. Everything was ok until my engine over heated and turn off on me. I need help
Sounds like the coolant got to some electrical parts
If you have compressed air then blow out the visible connectors Then should check for the basics Fuel, Air, Spark, Timing, Exhaust, Compression, etc. .... That should lead you to what happened Good luck |
