2004 Elantra 2.0 HVT XD Brakes
Old 08-07-2010, 07:56 PM
Alan298's Avatar
Default 2004 Elantra 2.0 HVT XD Brakes
Hi, I am currently replacing the brake discs and have done the front with no problem. So far I have only tried to do the rear R/H but am unable to push the piston back in while using a piston tool. Any advice would be appreciated. Regards
Old 08-08-2010, 07:37 AM
The piston on many (but not all) rear calipers must be turned when pressing it back in. Generally this is the case where the emergency/parking brake is part of the caliper and not a separate drum brake inside the rotor hat. The Elantra does use the caliper as the parking brake and it must be turned to be compressed back in. You need a tool that looks like this:
It goes on the end of an extension on a ratchet and it twists the piston back in (clockwise). Find the side of the tool where the studs best match the grooves in the piston.
See here:
http://www.youtube.com/watch?v=QuLEx...eature=related
Old 08-08-2010, 08:12 AM
Alan298's Avatar
Many thanks for your advice and the link to yjre video. Now I know the procedure I am confident I will be able to fit the new pads. Thanks again
Regards Alan
glassfern53
09-05-2015 02:47 PM
bugsy1989
12-18-2009 08:11 AM
pabeaure
08-21-2007 08:57 AM
rival22
04-04-2006 10:34 AM
tom scarano
02-22-2006 03:56 PM
Quick Reply: 2004 Elantra 2.0 HVT XD Brakes
