-   -   front end noise...cv joint? (https://www.hyundaiforum.com/forum/general-tech-help-5/front-end-noise-cv-joint-3350/)
xxfroehlichxx Nov 12, 2007 06:41 PM
hey hows it going...i have a 2004 sonata 2.7when i accelerate over about 25 mph, i hear a constant clicking from the front driver side wheel. if i turn left it gets louder, and if i turn right it goes away...i was thinking like a cv joint or ball joint....any suggestions or experience would be appreciated
Doohickie Nov 12, 2007 09:51 PM
RE: front end noise...cv joint?
If it has less than 60,000 miles on it, it's still under the warranty. Take it to a dealer.
In my experience, though, a bad CV joint doesn't make noise except when you're turning. It could be the brake slightly rubbing on the rotor. Are you sure the wheel is fully torqued? If some of the lug nuts are loose it can make some strange noises.
