frt wheel bearing
Hi all I am new here I have a 2003 accent how hard is it too replace frt hub bearings does anybody have a copy of instructions they can e-mail me
Gerard |
RE: frt wheel bearing
its not that hard at all.
Remove the wheel, take the caliper and pad bracket off (leave the caliper on the brake line!), remove the rotor, undo the axle nut, pull the bearing out, pack the new bearing and install. Easier than it sounds. |
Quick question: I thought the frt wheel bearings were 'pressed' on and needed a special puller to remove them???
(and something special to push the new bearings on??) CC |
