Fuel pump-or not
Old 08-07-2005, 08:29 AM
bug_n_67's Avatar
Default Fuel pump-or not
I have a 97 tiburon not starting as I tried four or five times last night.I removed the fuel line at the filter and had no fuel coming out when I tried to start so I thought it was the pump.This morning I went out and tried and it started right away.So now I'm not sure what it might be.Any idea's that you might have would be great.Thanks
Old 08-08-2005, 06:34 PM
hyundai tech's Avatar
Default RE: Fuel pump-or not
It could be the relay connection or possible connection at the pump.Easiest way to diagnose this problem is to remove the rear seat and gain access to the fuel pump plug connector. You will have to look at a wiring diagram and take a voltmeter to see if you have proper voltage. After you figure that out you can decide were to go from there.
mcbakker100
06-19-2017 06:58 PM
bglick12
07-16-2010 06:19 AM
bluemax229
07-12-2006 01:18 PM
mvjimenez
04-19-2006 11:01 PM
2loud2k2xd
03-18-2006 07:38 PM
Quick Reply: Fuel pump-or not
