headlight problem
headlight problem
I have a 2005 Santa Fe and the dim lights quit working. I have checked the fuses that are associated with the headlights and they all seem to be ok. The fog lights work and the highbeams work. I have turned the light switch to all settings and they just won't work. I have not removed a bulb yet because I can't hardly believe they would both go out at the same time. Any suggestions?
thanks
thanks
Well, I did not get any suggestions so I went ahead and replaced both bulbs and they now work. I find it odd that both bulbs blew out at the same time but I guess stranger things have happened. Hope this may help someone else sometime.
