heater control knob/assembly
Hey guys, first post, just picked myself up a 2000 Elantra gls as my new DD.
Factory radio didn't work so I wanted to install an aftermarket head unit. When I pulled the center bezel out to get to the old head unit, the hot/cold knob had come off, along with the assembly behind it. After reinstalling everything, the knob apparently had cracked and was just spinning on the shaft, making me unable to select hot or cold air temps. I found out soon after that the assembly itself was binding up, and not allowing the blend door to operate. Me being the impatient person I was, ended up trying to force it and broke the assembly. This assembly I speak up consists of some small gears and a cable attaching to the blend door flap down next to the gas pedal. Does anyone know if the dealer will carry this item? If not, where can I pick one up at besides the junk yard? |
