Ignition coil on a 2005 xg 350 l
Does anyone know if 1.66 ohms of resistance sufficient for my ignition coil to run properly? I can't info on these anywhere.
It's a 2005 Hyundai Xg350 l.
Thanks.
My car has no spark. Not sure what it could be so I'm testing the ignition coils...
Thanks.
Don't know the proper resistance should be
But, have you check power and ground to the coil?
And then there is the signal to fire from the ECU?
If those are there then it is likely the coils are bad
If not then restore those things first.
Or chase down the issue.
collectiveMDK
Jun 19, 2017 07:02 PM
TheSuperPony
Jul 7, 2013 11:16 AM
faheyk1981
Apr 17, 2008 11:33 AM
