-   -   Ignition coil on a 2005 xg 350 l (https://www.hyundaiforum.com/forum/general-tech-help-5/ignition-coil-2005-xg-350-l-16853/)
Robs Page Jan 7, 2018 05:54 PM
Does anyone know if 1.66 ohms of resistance sufficient for my ignition coil to run properly? I can't info on these anywhere.
It's a 2005 Hyundai Xg350 l.
Thanks.
My car has no spark. Not sure what it could be so I'm testing the ignition coils...
avisitor Jan 7, 2018 08:26 PM
Don't know the proper resistance should be
But, have you check power and ground to the coil?
And then there is the signal to fire from the ECU?
If those are there then it is likely the coils are bad
If not then restore those things first.
Or chase down the issue.
