keyless remote unlocking problems
Having trouble with unlocking from the remote,lights flash but doors wont unlock,I can hear the relay inside the car clicking,probably to send power to the actuaters but they dont work.They do work manually with the door button and the remote works for locking,any suggestions?
RE: keyless remote unlocking problems
Most likely the unlock relay. Not really sure where its located on that car.
Year /make and model please?
possibly corroded therminals at the actuator.
Having the same problem on an 02 Sonata. Except the interior lock button will lock all doors but will not unlock. Does the interior button / switch contain a reciever module for the remote?
ORIGINAL: stauto Having trouble with unlocking from the remote,lights flash but doors wont unlock,I can hear the relay inside the car clicking,probably to send power to the actuaters but they dont work.They do work manually with the door button and the remote works for locking,any suggestions? |
I had the same problem with my 2002 sonata. I had to replace the door lock
relay. There are 2 relays on the backside of the fuse panel (below steering wheel). They are about an inch or so long and are black and have 3 prongs on one side & 2 on the other. The way I initially tested it was to switch the 2 relays because they are the same (Info on relays is HMC DECO 95225-38300). After switching them, the unlock function worked on the remote but the lock did not. After replacing the bad relay, both worked. Good luck. |
Similar Problem
Could not lock my car. Located relay's on the BACK of fuse panel and replaced them. Tip: the reasons I have for replacing both is; 1. things seem to go in 2's on this car. Mostly headlights and lamps. One goes out then the other..... 2. where the relays are is a pain to reach if you have big hands like me. I already had to remove the lower dash ....might as well get both replaced. It was only a few dollars more.
Thanks to MILLER1 for your post. Finally found the relays because of your post. Appreciate it. |
