Location of Fuel Pressure Regulator
Fuel Pressure Regulator location on a 04 sonata with a 2.7 LTR engine
When someone requests the location of a particular component, there is usually a pretty good reason.
Maybe we might be able to save you some trouble and that is by asking what is the problem. Just getting a code is not always the answer. For example, if you are going by a code alone and you decide to replace the fuel pressure regulator and that does not correct the problem,you just spent a sum of $$$ and time and still have the same problem. If it were all that easy , half the shops would close up because the rest would become parts changers. Unfortunately they haven't invented that tool that does everything so what do you say, want to tell us maybe why? |
Originally Posted by hanky
(Post 58853)
(Post 58853)
Good point !
Now we have genuine smart **** suppose you tell him where it is ? And for your information, Profanity is a feeble mind trying to explain itself forcefully, suck it up ! |
Looking for my other half for the night
Free relationships without drama and obligations.
Verified Damsels |
