Metallic Noise at Startup
Old Jul 25, 2024 | 07:33 AM
Yernaz's Avatar
Exclamation Metallic Noise at Startup
I’m dealing with a weird issue on my 2018 Hyundai Accent that my mechanic hasn’t been able to figure out. When I start the engine, there’s this loud metallic scraping noise that lasts for about 3-5 seconds. It starts right when I turn the key and goes away once the engine is running. After that, everything runs smoothly with no strange noises.
Guys checked everything they could think of, but they still don’t know what’s causing it. The noise is pretty loud and metal-like, so I’m thinking it might be something with one of the moving parts.
Has anyone run into this before or have any ideas on what might be going on? I’d really appreciate any tips or advice!
Old Aug 10, 2024 | 08:26 AM
jbragues's Avatar
Sure sounds like something internal in the engine aint getting lubed up quick enough at start up. as in oil starvation issue keep an eye on it.
Old Aug 12, 2024 | 05:11 AM
Yernaz's Avatar
Thanks for the suggestion! I actually found the solution to the issue. It turned out that the noise was due to a loose heat shield that was vibrating during startup. I tightened it up, and the noise is now gone. Thanks again for your help!
Tbone106
Jun 13, 2023 04:30 PM
trggobog
Nov 28, 2022 07:34 PM
CAW
Jun 12, 2012 03:54 PM
hoffy5
Jul 19, 2010 06:44 AM
misstibs
Jan 3, 2005 11:40 PM
